New Topic New Reply
Author: Subject: Is this strong enough?
maartenromijn
posted on 14/10/08 at 01:14 PM Reply With Quote
Hi guys,
What do you think. Will this be strong enough?? Items are not yet finally welded.
STEERING RACK MOUNTS:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2IMG_0063.JPG
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=IMG_0064.JPG
AND HANDBRAKE CABLE BRACKETS:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=IMG_0066.JPG
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=IMG_0070.JPG
BLOG: http://thunderroad-super7.blogspot.com/
tegwin
posted on 14/10/08 at 01:18 PM Reply With Quote
Its hard to say whats what with such large photos..
But I would have to say no on both counts...
Most of the steering rack loads will come from the sides....and those brackets look too thin and have no rigidity from lateral forces..
Likewise the handbrake cable mounts....The materals looks a bit thin....can you "box" it to give it strength?
www.verticalhorizonsmedia.tv
maartenromijn
posted on 14/10/08 at 01:27 PM Reply With Quote
The rack mounts are made out of 3mm steel. I am considering a brace between the both mounts. Alternatives:
1. angle iron, welded level between both mounts
2. strip, welded diagonally between both mounts
H/B cable: is it an option to weld 3mm triangular plates between the axle and the brackets?
Mr Whippy
posted on 14/10/08 at 01:29 PM Reply With Quote
a second for boxing them in like this-
good weld quality though
Image deleted by owner
[Edited on 14/10/08 by Mr Whippy]
maartenromijn
posted on 14/10/08 at 01:39 PM Reply With Quote
Sorry, one picture was wrong. Here is the one i meant.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2IMG_0070.JPG
MrWhippy:
Is this to strenghten the mounts in the length of the car?
Do you think it also needs a brace to strengten it from left to right? I have seen examples, I think Westfiels does this.
maartenromijn
posted on 14/10/08 at 01:48 PM Reply With Quote
Hicost, do you mean like this: Rescued attachment IMG_0064 tubes2.jpg
posted on 14/10/08 at 02:05 PM Reply With Quote
I think he means left to right across the width of the car.
If you imagine the force of the steering arms it works mainly left to right and not front to back. Therefore you need to brace the brackets in the left to right plane.
posted on 14/10/08 at 02:11 PM Reply With Quote
maartenromijn
posted on 14/10/08 at 02:18 PM Reply With Quote
Nick205: Yes, I understand.
Still I don't exactly understand what hicost means with 'bending tubes' and 'welding to chassis uprights' ?
posted on 14/10/08 at 02:22 PM Reply With Quote
re-reading it nor am I
dogwood
posted on 14/10/08 at 03:23 PM Reply With Quote
i also think it needs some cross bracing to prevent lateral movement.
I did it like this
Mark Allanson
posted on 14/10/08 at 06:37 PM Reply With Quote
mark chandler
posted on 14/10/08 at 09:31 PM Reply With Quote
Before you get carried away and weld it fully stop!
Even 1/4" out and it can effect bump steer, have good search on this, build up all the front suspension, take out the springs and locate the rack in the best position before you fully weld and brackets/supports in place.
New Topic New Reply
