chrisspartan
| posted on 14/10/08 at 11:40 PM |
MK Full rollcage dimensions - Can anyone help?
Hi, I am drawing up my full rollcage for my MK Indy was wondering if anyone could help me with the MK factory rollcage dimensions as shown below.
I am 6 ft 1" and am assuming I would fit under a standard MK rollcage with a helmet on?
Thanks in advance
Chris
[Edited on 14/10/08 by chrisspartan]
welderman
| posted on 15/10/08 at 06:48 AM |
ive got a spare cage knocking around will have a look later for you
Thank's, Joe
I don't stalk people
welderman
| posted on 15/10/08 at 10:04 AM |
Thanks in advance
Chris
A = 450mm
B = 1000mm
C = 900mm
Not a factory cage, one i made up for someone, but made two.
Thank's, Joe
Kriss
| posted on 15/10/08 at 10:40 AM |
on an MK, it is possible to have the front mounts outside of the cockpit, being tall, my knees would interfear with it.
chrisspartan
| posted on 15/10/08 at 11:56 AM |
Thanks for that welderman.
Kriss - I am planning to mount the tube inside the chassis but then bend the tube outboard of the chassis once I get to the top rail to give more
elbow/knee room. I think thats what Mk do themselves.
procomp
| posted on 15/10/08 at 01:32 PM |
Hi
I have said it many times but if you are ever thinking of using it under MSA conditions. Then i would do the research on what is allowable and what is
not. All is clear if you consult a MSA blue book.
research how big a degree bend is allowed in the top tubes and what is allowed in terms of bends on the front roll-hoop and especially how it is
mounted to the chassis.
Cheers Matt
Kriss
| posted on 15/10/08 at 01:45 PM |
yeah, i know how MK do it, i just think i will have issues around the knee area, its so tight already!
good luck with the build
