hellbent345
posted on 21/10/08 at 08:10 AM |
haynes roadster shock absorber brackets
to fit original IRS driveshafts without cutting them down you have to extend the rear wishbones by 10mm or so, i would like to know if i should move
the shock mount out by 10mm as well? or more? on my solidworks model it looks like the damper is at max travel at normal road height, so no droop at
all? thanks al
designer
posted on 21/10/08 at 01:44 PM |
A set of drawings for the +10mm suspension arms is available on the roadster forum.
davie h
posted on 21/10/08 at 03:20 PM |
i made my wishbones 10mm longer a lot easier than moving the brackets
Davie
http://www.flickr.com/photos/24179682@N04/?saved=1
3GEComponents
posted on 23/10/08 at 06:37 PM |
Hi Al,
With your model are you using the standard 13" shock, or the ones with the 1" spacer fitted?
I take it that you are asking about the top shock mount position, and there's no reason why not, just remembe to make sure that you can still
get the bolt through the hole in the bracket.
Regards
John
Ninehigh
posted on 25/10/08 at 07:02 PM |
I'm not at that stage yet but no doubt what I have won't fit. Imho I'd move the brackets, adjust them to fit and then make sure it
all moves
