sva fail,but I'm still happy
eddbaz - 22/12/08 at 05:46 PM
Failed sva this morning,but only on a few minor points one of which I wouldn,t have been able to rectify at the test station.
I have a fueling problem that only came to light on friday when I was having the engine mapped for emmissions,Got round it by using the power commander and it was touch and go weather it would pass emissions,but they passed so I'm happy.
Examiner at Nottingham Martin was very helpful and he commented on the quality of my build which was nice.
Need to sort overfueling problem and get a couple of small jobs done,then back for a retest.
BenB - 22/12/08 at 05:49 PM
A good fail!! Always good. Nice quick fixes before IVA comes in!!!!!
afj - 22/12/08 at 06:05 PM
better luck next time fatty
[Edited on 22/12/08 by afj]
peterparsons - 22/12/08 at 07:04 PM
What are the small jobs it failed on.
Mine failed Last Thursday, I've put right about 80% so far, looking for a retest mid Jan sometime.
eddbaz - 22/12/08 at 07:46 PM
Failed on:
Clocks don't illuminate when lights switch on.(minor wireing fix)
Wing mirrors (need to fit some different ones)
Rear lights and indicators slightly too low
(will be able to raise ride height with shocks)
Front lights( need raising around 15mm, easy fix)
Thats it, nice and easy.
Stuart_B - 22/12/08 at 08:07 PM
unlucky, hope you past the second time. at least they are easy fix's
stuart
merry christmas
locoR1 - 22/12/08 at 09:36 PM
Better pull your finger out and get it retested cant have Alan passing before you
Sounds like a good fail well done! looking forward to seeing it looks a really nice build.
Dave.........
matt.c - 23/12/08 at 10:44 PM
Thats a pretty good fail mate.
A few easy changes then it will be all over then you can start making plans for the post sva alterations.
afj - 24/12/08 at 12:10 PM
i think i know some of the planned alterations post sva namely a bigger engine so he can keep up with me
eddbaz - 24/12/08 at 04:40 PM
No need Al, the weight of your head will slow you down enough
afj - 24/12/08 at 06:00 PM
[Edited on 24/12/08 by afj]
