Afternoon all
With the weather improving and looking forward to finally putting some miles on the clock. The toe is still set to SVA with it out by about 1.5
degrees to aid self centring.
What should the proper settings be for normal driving afdter SVA?
Nigel
I've set mine neutral
Mine is about 1 degree toe in.
stu
Little bit of toe-in that will go to neutral when you plant your right foot....
Hi Nigel
Toe in. had mine out a few times round the block, M53-A55-top chester road- home, horrible trundling down the motorway at 69.9mph having every richard
head wanting to race you and you know you've got another 5500 revs to go,after 40 odd years with a clean licence and a job that requires a clean
licence. it's killing me
Just thought if your steering wheel is aligned properly take it about 1/4 turn each side so as you keep your steering wheel aligned,
tony
[Edited on 17/3/09 by mad-butcher]
