I'm seriously thinking of having a go, but in order to do it I need the assistance of a type R owner to provide a rough drawing and dimensions of
the top rockers and any photos of the bare chassis showing mounting points for rockers and dampers and also length of connecting bar between lower
wishbone and rocker
many thanks
tony
Would it be more effective to re-build onto an IndyR chasis?
As I understand it the rear suspension improvements are as important if not more than the front end.
Again my understanding is that the bodywork etc is the same so you should be able to re-use pretty much everything.
Obviously a more costly approach, but ultimately would give you what you're chasing I think.
Sounds like a good project. Do you hope to gain anything from it, or is it more for the fun of the project?
[Edited on 22/5/09 by Frosty]
Are you sure the bones and chassis pickup points for the bones are the same on the normal and the rocker chassis?
Normally they would be different to make the best use of the progressive action of pushrod suspension.... I might be wrong.... but you never know :p
i have a gallery of early part of my build here:
http://picasaweb.google.com/danwright87/Kitcar#
lots of pics from chassis / suspension.
is this not a winter job? its sunny and warm outside
quote:I think there would be a bit of planning etc to be done first. I don't think that Tony is planning to do it this afternoon (although I could be wrong - It's not that sunny over this way at the moment).
is this not a winter job? its sunny and warm outside![]()
It may be sunny and warm where you are
Its chucking it down here.
Kipper.
Originally posted by kipper
It may be sunny and warm where you are![]()
Kipper.
piss off
Kinda nice here too - shame I'm stuck with the kids all afternoon...yhey'll just have to come to the tyre fitters with me
and you ain't getting no sympathy either.
ANYONE ELSE
Seriously if it wasn't on 888's I'd be out in it, bit of rain never stopped me riding a bike
tony
Retro fitting inboard suspension seems kinda pointless to me. Loads of work for very little/no benefit
Phil
Going out in 888's in the wet is better than going out in 'em in the dry!!!
