i know this has been discussed to the death here and i have done searches and found some info, but i am about to buy some some wheels they are 19mm
offset, i know most ford ones are 35mm, but someone previously said that RWD ford ones are 19mm.
Basically i want to know if these wheels will fit under the rear arches? and they wont mess up the suspension geometery or anything. I take it front
wheels wont be a problem as the brackets can be bent to suit.
Basically how much room is there inside the rear arches, as the wheels will stick out around 20mm more, the tyres are 205mm, im guessing the people
with 17s are running 225 so that means the wheels i would like only stick out 10mm more than these.
My wheels are 15 mm offset, for SVA I have spaced my rear arches out by 20mm as it was a bit touch and go on clearance, I am sure the spaces will fall
off after SVA
I would say the 225's or even 205's are a bit overkill on these types of cars, 185/55R14 (on sierra wheels) fit perfectly in the arches and
grip like a bugger too! Light weight is the key to handling and acceleration and gert big 17" weigh a ton
Ben
MK spec a ET35 or more for the very reason stated, too little offset leaves the wheel rim outside the rear arch. The Sierra uses a ET40 rim, and I suspect the front upright was designed to be used with this offset to give the correct steering geometry. Most after market wheel suppliers supply ET15 for older RWD Fords and ET35 for later RWD and FWD, found a few which go up to ET52 if you want to fit wider tyres. I'm not sure i would go more than 205 though.
I have found a set of wheels that i really want, they are 16" so not too big, but they have 205 tyres on them. They wont fit under my cycle wings, so will fit 195s on the back, want dont want to spend too much so want to keep the ones on the back, also means i have a spare set of rear tyres.
