Hi Guys
Do you know if the diff just mounts on the chassis direct or whether there are any rubber parts that need to mounted with them to house the diff
etc?
thanks
James
2 X M10 thread bar me thinks
No rubber needed
bare back you could say!
Either threaded bar or looong bolts, I'm pretty sure they're M12.
Best to put it in from below with someone to stick the bolts in/catch the diff when you drop it.
Hardly anyone fits any rubber to the diff - although i've been told its a really good idea to cushion the diff to stock the shock foces being transmitted to the chassis.
m12 x 208mm long high tensile bolts
or the easy way, long bolt on bottom, 2 allen bolts in the top, heads inside nuts on outside, the reason.....you'll find out if you use 2 long
bolts.
tony
Originally posted by mad-butcher
the reason.....you'll find out if you use 2 long bolts.
Used threaded bolt in the end and the top one was a bit of a challenge wiggling it past the chassis but was fine after that.
thanks for all your help
j
