Hi
Could someone tell me what the length the bracket should be i.e the distance from the chassis to the front of the bracket. I have just had some made
up by MK ( I'm sure they know what they are doing) but I have trial fitted the nose and it feels like it will foul. Is basically the rule of
thumb that I should be getting the radiator as close to the chassis and front suspension as possible?
Pete.
Have you got the MK specification rad ??, they are open in the morning give them a call
Yes I bought the rad, brackets and fan all at the same time.
Pete.
Mine were too long, I had to modify them by grinding a bit off the ends.
