Has anyone found a decent solution for how to secure the cable as it comes through the bulkhead at the pedal end (on an Indy if that makes a
difference). I don;t mean the nipple, I mean the bit that stops the sheath moving?
If I've read that right then I'm also interested in the answer as I'm sure my outer cable needs some kind of double rimmed top hat fitting to it.
I turned a top hat from a bit of nylon bar and drilled it through then drilled half way slightly larger to hold the cable.
Steve.
the cable usually (not all of them do though) has a stepped metal end on it that goes into an adjuster. all you need is a plate with the right size
hole in it
if your cab;e hasn't got a stepped metal end on it, i'd look for another one that does
Mac1 supply what your after.
i used a rivnut
n tapped a thread on the cable end so it screwed in the rivnut
did the same the other end too
only because i remembered how they used to work on chopper bikes
On our Davrians we use the bottom bit of a rubber snap in tubless tyre valve.
I got mine direct from MK.
