hi i have a accusump and wondered if any one has fitted one to a suzuki gsxr1000
its a k4 wondering were people piped it into oil system ??
oil cooler pipes ???
or a plug in end of oil way were it was drilled in factory then pluged ??
any advice would be good
mines plumbed into the block right on the end of the oil galery, straight into the block is best. andy at a b gave me my advice
thanks i saw the big allen bolt/plug at end of block so no one way valve needed ??
theres no one way valve on mine the pressure in the accusump means it is always above that in the engine so it can not return. im using the elctric valve though so the mech one may be different
yer mine has a electric valve too so ill just weight for it to turn up and see what i need to plumb itup
