I've finally got round to measuring the castor on my car and it is around 3 degrees on the drivers side and 4 on the passenger.
I'd like to correct this, so I have 6 degrees both sides, and so get a bit more self centreing.
So I can either modify / make new wishbones or grind off the chassis brackets for the top bones and weld some new ones on in the right place.
It seems to me that moving the chassis brackets is easier.
Anyone done anything like this already?
Stu
Someone on here (can't remember who, sorry) makes/made some upper wishbones for the indy that were rose-jointed, meaning that the fore-aft position of the wishbone could be changed by padding with spacers.
Ah, sorry!
Now I'm looking at the car it's clear that the brackets can't be moved so it looks like modified bones are the only solution.
Has anyone modicied their own Indy bones for more castor?
Stu
[Edited on 21/4/10 by whitestu]
I'm lucky to have a set of the rose jointed ones, but before they appeared on the scene I thought it may work to just reduce the length of the tubes that take the polybushes and mount the wishbones at the rear of the chassis brackets, with washers in front as packing.
Does anyone have a CAD drawing of what is required for a replacement top bone?
Thought I might ask one of our fabricators if he could knock up a set.
The rose-jointed wishbones are a great idea, but the problem is the rose joints, which just won't last in the road, and most Indys will do at
least some road miles even if they are mostly used on track.
The spacing of the wishbones is a brilliant way of correcting one of the inherent flaws in the Indy though.
Reducing the bush housing length would work, but I think accuracy would be difficult to achieve.
Give MK a call, I'm sure they could fabricate and supply you with rose-jointed top wishbones for the Indy.
We modified a pair of Indy wishbones to accept a camber adjuster and rose-joints.
Phil
[img][/img]
Thanks Guys - some good ideas there.
Phil, what castor angle do you have now with the modified bones?
Stu
U2U sent...
Currently running at 6 degrees IIRC
Phil
I've ordered some rose joints so I'll have a go at modifying the bones when I get some time.
Thanks for all the advice.
Stu
