I'm going to have to sell my unfinished MK Indy. Ideally I'd like everything to go in one lot because my circumstances mean I'm
unlikely to be able to be around for people to pick up individual bits.
Any idea how much I should ask for this lot? Nearly all parts are new (except g/box, diff and steering column). I have the sierra donor V5 inc cut out
chassis plate.
MK Indy chassis (standard black powder coated)
floor, sides and scuttle fitted (all bodywork included - black gel coat)
Bonnet inc bulge/vent
All suspension fitted
Brand new 2 litre zetec fitted to type 9 gearbox
Shortened prop
Diff fitted with reconditioned drive shafts
Wilwood 4 pots and discs on front
rear disc conversion using VAG calipers and cossie solid discs
ali fuel tank and sender
Copper fuel and brake lines fitted inc adj bias valve
New 16" OZ wheels and pirelli tyres
New sierra uprights at front
new quick rack
Swirl pot, LP and HP fuel pumps
Not fitted but also will be included
new starter motor
Used but as new Griffin power systems inlet plenum/manifold
2 injector rails inc injectors (one new; one used)
Spare 16" OZ alloy but no tyre (just in case of kerb damage to one of the others)
Low and high pressure fuel pipes
There's probably even more but can't think at the moment
If anyone could give me some advice on how much to ask? I dare not count how much I've spent on this. I have all the receipts, manuals etc that
have come with the new bits
I'm gutted to think I'll never be able to finish or drive it, but needs must.
James
a very rough guess-timate £5k.
only from comparing to others i've been watching out for.
As with everything though, its more about what someone is willing to pay.
Not sure how much the engine is on its own though so i've not really counted for that.
wasnt there someone on here selling an Indy and looking to buy on that required building ?? if hes still looking you may be able to do a bit of a deal you would get to have a completed car he would get to build and possibly some cash in your pocket. Cant recall his name but his avtar was a motor home if that helps any
Thanks guys - it will have to be a sell because I probably wont have a home let alone a garage for much longer.
Any further guidance...?
u2u sent
