Has anyone got any pictures of where to run the brake pipes on an MK Indy R.
I'm a little nervous about drilling holes in the wrong place.
I have searched but I can only find pictures of MK Indy's.
Don't overthink your build or you'll be building forever and never driving.
The route the Indy brakes take will be the same as the R (give or take!)
You could have a gander here:
http://www.p4nts.co.uk/specr
hi there
im in the same boat as you keep putting it off but its time to dive in if i find anything ill let you know but what i will say is the
main brake line to the rear seems to be far to long do you have that as well
craig
Originally posted by main82000
but what i will say is the main brake line to the rear seems to be far to long do you have that as well
craig
quote:Sounds like sound advice to me!
i'm on year 10 of my build ........ guess what i keep doing!!!!
hi there
yes sorry i meant the pipe that came with the kit is to long as you say i will need to cut and re flare craig
If the pipe is to long you need to cut it to size with a pipe cutter. Then use a tool to flare the end again.
http://cgi.ebay.co.uk/DRAPER-37870-BRAKE-PIPE-FLARING-TOOL-KIT-7-PIECE-/150464712738?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item23086550
22
There are loads of indys around peterborough/spalding/holbeach areas some one will be willing to give you some pointers i could take a drive over at
the weekend to give you a hand for an hour or two or have a search on google for mk indy hellfire there are pleny of pics there not a indy r but its
all the same really
alan
Brake line on left, fuel on right
Brake line
Originally posted by afj
There are loads of indys around peterborough/spalding/holbeach areas some one will be willing to give you some pointers i could take a drive over at the weekend to give you a hand for an hour or two or have a search on google for mk indy hellfire there are pleny of pics there not a indy r but its all the same really
alan
