Anyone have pics of how to vent the engine bay?
something like
Just about the same as the Dax Rush option.
Basically a tapered large 'U' channel in place of the falt sheet normally fitted.
Rush rear view
In most builds most of the hot air from the engine bay goes down the tunnel a well shaped diffuser could help draw more air through.
The MK panels can be inverted and cut to provide the effect youre after. Talk to them about it, and they should give you the information you need. Failing that, there are other Indy owners that have done the same.
I went made with the hole saw !
The floor is flat on mine, just a small hole for the sump
In the garage
Some in my www button below.i just let dad go mad with a hammer and some wood!also a big vent in my scuttle where the wipers mount.saw one at a show similar to your picture but more of a triangle than rectangle section that looked well,almost stealth bomber lines.i'd imagine it'd be easy to do too.
This is how mine are, very easy to do.
Thanks these are all good ideas
