Anyone know the Gauges used for the following on the MK Indy R
- Chassis
- Sheet used for the floor
I am trying to buy a set of Rivet Nuts and want to make sure I get the right grip range..
Hi just called MK for you chasis gauge is 1.6 mm wall thickness and floor is 2mm thick
