Well all the hard work done total rebuild of the engine,fitted and it runs
But i have broken the speed sensor bracket and canot work out were it
goes.The pick up is from the diff linkage any pictures would be a great help.
take a photo of where it should be and i will show you mine - im not 100% sure where your on about
did ya find this bracket??? as i dont have a bracket for mine either??
haha, its brilliant isnt it, im stuck on this now too,
the speed sensor used to attach on the casing that went over the sprocket, as we have to cut this away to fit the sprocket adapter we no longer have
the mount point
so what did you guys do, and what did you attach to the prop to get a speed reading?
