this has been probably discussed several times but what do i need to do to get the emissions to meet teh MOT requiremenets? can i just stick a temp
CAT on teh system or do i need to get the power comander remapped with a CAT?
cheers
Rog
Might help if you say what engine and what year it is, also is the car registered already?
lol, i am thick some times, its an MK indy with a GSXR1000 K6 engine. not registered yet so need to think about the IVA for next year.
You're going to need a cat' and then to play with the PowerCommander map to get the emmisions within limits.If you're luck enough to
get through without that, will you pick some lottery numbers for me
i wont be that lucky, never won nothing on the lotto!
do you know if there are any power comander maps floating around on the forum that people are sharing? i was planning to get a map set up on the
rolling road when the car is on the road but could do with a map for the IVA if someone else has already gone throught the pain of it.
hi rog
if you are intersted you could just hire our CAT and we could set the car up for the emmisions.it takes a couple of hours £100.
thanks danny
Hi Danny, ya cheers for that, i will keep you in mind when i get to that stage of the build
cheers
Rog
