I have just bought an early MK Indy project. Chassis is live axle, late 90's, but never built. There are other parts with it, but any tips?
Any insumountable issues with these?
Which bodywork fits?
Is it based on Champions plans?
I will need some parts, so let me know what you have spare please.
Colin
May be the same Chassis as mine then, its not called an Indy due to the live axle
I fitted mine with a pinto engine but had to raise the side of the chassis by adding more box section too the top rails
Im now currently fitting a duratec engine.
You may find the self centering to be a pain, We had to chop my wishbones up to sort this out, but once done it handled like a dream.
My live axle is actualy from a capri too, which gives an extras 2inch either side.
Mk Indy bodywork will fit just fine.
Give me a shout if you want to know anything else
Patrick
Patrick
Yeah, the wishbones worked fine except that they just would not self centre, I believe this is common on the mk indy too. but dont hold me to that.
Redeye, so if it isnt an Indy what is it called?
Problems with self centreing, did you actually do a geometry check on it? Too much caster?
I was thinking of putting rose joints on to adjust caster and camber.
Engine will be a crossflow to start. Just because I have 1 lurking complete with a 5 speed!
Any idea what shock absorber length should be? I have been offered some but not sure what they should be.
Was there any sort f build manual for MK, or is just Haynes?
Colin
Indy with a live axel Nindy?
Any chance you could post a pic up of it my mate would love to see if it's anything like his
Colin
Colin
The design of the wishbones gave pretty much no caster, so we moved the centre of the wishbones towards the rear. this worked a treat, It was a friend
of mine that actually modified them and at the time he didnt have any round tube so just used box section, this worked well but looked aweful so Ive
recently had them remade by a locally.
My car was one of the earliest chassis built by Mk long before they started making the Indy and yes its pretty much based on the book. Ive been told
it was built in Martin Keenens own garage before he actually started the company, but rest assured all Mk chassis are usually very well put
together.
Theres photos of my car in my photo archive if you want to see if its the same style chassis
Its handy that you have the crossflow since this is the engine the chassis was designed for, so you shouldnt have any real problems.
theres no build manual but its not really needed, just use the search function on this site to find all the answers you'll ever need or ask if
you cant find them.
Where are you based btw?
Good luck with the build
Patrick
So it was you bidding against me .............
Obviously I wanted it more than you!!!....
Colin
Redeye, getting back to Shox, have you got any dimensions `please.
Colin
It's just an MK Locost and I've got one. Most are live axle but there are some de-dion.
The Indy came along later.
Not sure. Im not near the car at the moment but ill measure them up when I get a chance.
If they are the same as the book chassis then someone on here may be along to tell the lenghs needed though
I am trying to load a pic, but dont seem to be able to
Is that because I do not have enough posts?
Colin
Colin
Aah, sorry I dont even know how to do it!!!
Aah, sorry I dont even know how to do it!!!![]()
Should be a pic here now!!
CP
Bollocks!!
It didnt work. That was supposed to be a link to Photobucket.
How do I do this? The pic is only 22kb.
CP
You will get the hang of it
Thanks Paul!!
Please tell me how you did it!!
colin
Thanks Paul!!
colin
Cheers mate. Managed to change the Avatar now
Colin
