Kind of lucky that I never went on a run to Chew Valley.... Due to having the grand-kids I only went for a local run out.. LUCKY I did! When I came
back for some strange reason my fan was running
Temp read just over 100..
Thought nothing of it untill I moved the car and noticed fluid all down the left side of the car.
Took off the nose cone to find this..
Lost 2 litres of fluid!!! I have replaced the hose clip and had a test run and all is fine again.. Runs at 78 degree's..
The joys of a kit car.. I LOVE IT..
If that is the fitting above and left, there is no barb on it, plus those stiff jubilee type clips aren't best on thinner hoses, the thin narrow
stainless clips perform better.
Id put a couple of saw grooves round that fitting too to try and create a bit better grip.
Simples the hose clip was far too big for the OD of tubing.
Araldite some welding wire around the plastic fitting, then jubilee it on?
All the above, no bead on the fitting, clip to big in diameter and section.
Fitted a small clip (fuel pipe type) and all seems ok now, touch wood. Pipe is also very close to the nose cone which dont help..
looks like a polo rad and someone has cut the fitting down,
probably because it is too close to the nose.
It's even more amusing when the hot water comes through onto your feet
Originally posted by Custardpants
It's even more amusing when the hot water comes through onto your feet![]()
It would of been fine if I had a passanger cause then would of noticed.. Any
way all seems fine at the mo
im sure I had that car up to 120' once !!!
Would rather that cause its an early warning that will make you stopIt would of been fine if I had a passanger cause then would of noticed.. Any way all seems fine at the mo
