Gents, looking to adjust the rear camber on my MK. any idea as to the sze of the nut at the back, the largest spannner I have is 26mm and it will not
fit. before I head of to the shops to by spanner of every size, any idea on the sie of the nut to adjust the camber on the back.
Craig
educated guess 30mm, measure across flats for size.
Hi
As previously stated measure across flats.
We had to fit double locknuts for the IVA.
Good luck
René
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Double%20lock.jpg
Double locknuts tightened and marked with tipex are a good idea. Mine came loose at bedford just as I came into the pits(!)
I have a stack of M20 Nyloc nuts, they came in a pack of 25, I only needed 2 for the MK
U2U me and I will pop a couple in the post.
This goes for anyone else who wants them.
[Edited on 12-10-12 by 40inches]
As above make sure you have some form of locking, managed to wire lock mine..
Dan
