Hi all..
once read a post about lots of eyes looking over people's work..
so thought this was a good place with lots of experienced eyes looking over my MK before its IVA test..
See my album...
all comments welcome..
thanks in advance..
Nice looking car and a great colour scheme
Thanks..
Wheel arches look a little too angled back, you need 30 degrees forward from vertical. Might be the camera angle but worth checking.
Side repeaters on skuttle will likely fail on 5 degree viewing angle from rear as rear arches will obscure them.
You will need a rear view mirror in the centre.
Is the rear fog absolutely vertical, it needs to be.
Front indicators need to be min 400 from widest part of car so will need extension arms.
Worth reading the manual again!
[Edited on 30-4-13 by loggyboy]
From cycle wings don't look to come forward enough. Also although hard to see in those pics do your front inductors cone out wide enough?
Looks nice.
Few things worth checking..
Check the requirements for the position of the front arches. Think they have to extend far enough forward to be ahead of the formost rim when viewed
from above. I could be wrong as that doesn't apply to my car.
Your side repeaters will fail the angles of visability test as the rear wings will obscure them. Fitting on either the front or rear arches seems to
be the way to go. Do a search to see what others have done.
Are your harnesses sloping up from the rear mounts to the holes in the seats? If so they'll fail as it makes the seat "structural".
Extending the illars they mount on so they're level or sloping down will cure (even though it'll be poor engineering and temprary)
Are all your required labels on? Brake fluid, balance bar, manufacturers plate (check required info as some have failed for not enough or too much)...
ok thanks..
keep em coming boys, if it doesn't fail the test i'll lay the first £90 down at the bar of a big meet up this year..
i will adjust my front arches tomorrow but i have seen a few with similar repeaters in the same place pass the iva..
the front indicators are spaced above minimum distance apart as per iva manual..
many thanks for the comments.. I am making a 'to do' list as we speak..
*POST HIJACK ALERT*
For your rear fog and reverse lights, what plinths are you using to make them vertical?!?
Aside from that, looks cracking!
the same as the others but machined to angle them so they are vertical..
going to look at the seatbelt thing tomorrow.. they currently angle up but do they have to line up with the seat holes? its only mm lower?
thanks for your assistance guys..
Originally posted by Acc8braman
You sure about this one, I not have one in mine?
Hi
Great looking car , well done
Just a few observations.
Exposed locknuts on trackrods
Central rear view mirror IVA compatible
Side indicators will fail , ours did.
We were told by Mr IVA man to put them
in the rear arches (see borrowed pict)
indicators
Front indicators need extensions
have you got one of these
good luck
René
2. An interior mirror must be fitted, (see note 3)
3. The vehicle must have an nearside exterior mirror fitted (if the interior rear view mirror gives no view to the rear or the rear window is less than 70% light transmittance) (see note 3 & 5)
Note 3: The interior mirror must be positioned as far as is practical to afford the best possible view to the rear, if the interior rear-view mirror does not provide any rearward vision its presence shall not be required.
Things we can't see are the emissions, noise, brake bias, reverse
Have you got these sorted?
i have moved arches round a bit and look fine with the angles in the IVA bible..
seatbelts are now level with the seat holes..
going to pop into VOSA and have a chat as its only 2 minutes away about the indicators..
Noise wise its well quite for what i expected it to be and there is no visable emsissions but going to test that this evening..
rear view interior mirror fitted.
reverse works fine and light works when the button is pressed..
thanks to Rene for the pics and info on replacement side repeaters
When is the test booked for? Don't leave sorting the emissions till the last minute, if the engine is post 1995 it will
have a CAT test.
the engine is 2002 gsxr 1000 fully rebuilt by Iane racing it has a cat in the exhaust so will find out more later..
I have only paid for my test this week so i expect within the next four weeks although i did select the asap box..
does anyone know about the seatbelt extensions for where the bolt mounts to the top bar of the chassis.. has anyone had an issue with an inspector
over the height?
many thanks Lads..
Which VOSA station are you near?
Gillingham.. had a few MSVA there and V.I.C checks there over the years and freindly bunch of chaps.. happy to share info so far..
Whats the radius like on the bottom edge of side and rear panels?
I had to stick 'tadpole' type edging onto the bottom edge of mine for IVA
I really want to fit a diff diffuser but been advised not too so abs sheet will go on for now to keep it tidy underneath..
Just popped round to Vosa to get my test date.. booked in for the 30th of may...
Caterham was there so had a chat and look round...They don't put anything round the lower edge and it has a similar 90 degree bend on the lower
edge as mine does but i believe they have a different test to amateur builders as its a vehicle produced in small volume.. Hence why their front
indicators don't sit within 40cm of the outside edge etc..
More worrying was the inspector looking over my bike parked as its got more bolt on goodies than Crescent can supply but its got an M.O.T so NERR in
your face Mr inspector!!!
Well excited now and thanks to all those that had their say on my pics as i have done all the mods recommended by these posts...
Emissions done and well and truly under co is reading 0.04 at fast idle of 2500-3000 rpm.. hc is less than a 100.. woo hoo..
Don't you need a rear view mirror ????
I have fitted one now but it'll be straight off after the test..
all mods are now done and counting the days to the test..
6 more to go!
