Hi there, just doing some final iva checks and putting some cable glands on my TRE extensions, now I'm sure I read somewhere last night that the
extensions get wound right on as far as they go, then you put the nut on the threaded end then put the TRE on to the extension, is this the case?
Or does it go-
Nut - extension - TRE
And use the extension for adjustment?
Could someone confirm, thanks in advance
Greg
Hi i have steering rack
nut
extension
and track rod end tight up to the extension
Jacko
Cool that's how I initially had it, then I read the Mk build manual and it put doubts in my head!
nut
extension
Jacko
