Just as it says i am looking for inspiration for lights layout at the rear, no Westfield / Caterham lookalikes or landrover cast offs.
Who has got the most original layout.
This is how mine ended up, next step was a set of LED lights..
Always happy to show off my rear end....
Me bum!
Originally posted by Mave
Always happy to show off my rear end....![]()
The brackets are custom (lasercut steel, which I TIG-ged together). The lights are Hella Premium units, the housing is actually two of the decorative
Hella rings, back-to-back.
Maybe this picture shows it more clearly:
This is mine
Jacko
Have a look at page 415 of the CBS catalogue. 95mm lights fitted in a mirror housing.
http://content.yudu.com/Library/A28q0c/CBSCatalogueIssue26/resources/index.htm?referrerUrl=http%3A%2F%2Fwww.carbuildersolutions.com%2Fuk%2Ft%2FCatalog
ue
[img]
rear view
[/img]
[img]
[/img]
The brackets are custom (lasercut steel, which I TIG-ged together). The lights are Hella Premium units, the housing is actually two of the decorative Hella rings, back-to-back.
Mave is out in front just now for most original.
ludobenc - 6/12/13 at 10:19 AMthis is mine:
[img][/img]
i don't like the 2 square lights
chrilla - 5/1/14 at 07:05 PMMy rear end, not quite ready yet, but will be for this summer i hope!
Hellfire - 5/1/14 at 07:16 PMHere's ours at dusk...
Rear Dark
Phil
hkp57 - 6/1/14 at 08:03 AMquote:
Very nice work.
chrilla - 6/1/14 at 08:37 AMThanks, I will put up more pics in my gallery so you can see how I made them.
I used a fire extinguisher as mould for the lights, and then a lot of work to get them in right angle and also waterproof from inside.
/Christian
