I've got a polo rad to replace the original factory escort one and I'm thinking it may not be best suited?
The lower pipe is fouling the chassis rail and possibly the steering rack and I cannot seem to get it any higher because of the nose cone.
Wondering if the civic or clio rad option maybe better?
Any help/advice gratefully welcome.
[Edited on 2/5/14 by marco]
The bottom of my rad was pushed out so that it could clear the chassis and the nose still fits
[Edited on 2/5/14 by puma931]
It is a bit tight but it does fit, I have more of an angle on mine.
Was close on the Striker, as I used a slightly wider VW rad (small golf IIRC) ,But I spaced it out to clear both rail and rack.
It will need an imedaite 90 degree pipe on the lower connection.
Mmm,
More angle will tilt the bottom hose more towards the chassis rail and I'm fairly sure I cannot go any further forward into the nose cone.
I will have another look tonight, trying to hold it in place whilst trying the nosecone is a real pain
I've got one on my Indy and don't recall any issues fitting it - I just made some brackets to sit it at the right angle to clear the
chassis.
Stu
You do need five pairs of hands for this job, but I don't think your far off. Here a pic of mine.
Rad
I made a 90 degree bend and a bit of fettling ..
If you look at the bottom hose .. not a great pic ..
Polo Rad
Hiya,
Here is a few pics of my polo rad brackets, the bottom hose clears
the chassis with a few mm spare.
Lee
Hey up mate fitted the same rad to mine with no problems. There are some pictures in my archive under the name radiator that might help you.
Ill pop some pictures in my archive of mine but youll get it with a mk nosecone mine is tilted away at the bottom and pipework is very close but will fit. Welcome to come look and i may have a few leftover bend that will help.
Many thanks guys, I'm on the case now all the pics are helping...
Managed to fit one to my indy. As mentioned above it is tight with the nose and you do need an extra pair of hands.
I used a Peugeot 206 top radiator hose for my bottom hose. It's 'S' shaped and fits nicely around the chassis.
Which Polo rad would you gents recommend as I need to source one for my build?
