Hi I bought a mk indy from someone else and I don't think that the camber angle is correct I've done a little research and I've come up with 1 to 1 and half 1/2 degrees, what should it be for normal Road use. Cheers Steve Float
Might be worth having a decent geometry setup. Don't alter camber angles until ride heights are set correctly!
If your happy with ride height,spring rate,wheel sizes,tyre pressures etc then a simple camber change may do the job. But a full setup with corner
weights will transform the car if not already done
