Amount of wheel nut turns
Stevie_P - 10/10/15 at 02:07 PM
Bit of a basic question from a novice builder.
I have some wheels for my Indy R and the nuts that come with them (Tuner style?) only turn just over 4 turns from loose to tight.
Build wheels (Sierra ST) with original nuts use about 7 turns.
Do you think 4 turns is safe enough or should I play safe and get longer wheel studs?
The originals are around 40mm in length.
theduck - 10/10/15 at 02:31 PM
I have more turns than that on mine and I ideally want loner ones!
coozer - 10/10/15 at 02:55 PM
Stud needs to be at least the length in the thread of the but. Are the nuts blind or open?
ian locostzx9rc2 - 10/10/15 at 03:53 PM
You need a lot more treads than that I would get some longer wheel studs .
Toys2 - 10/10/15 at 04:12 PM
Rough rule of thumb, the length of the thread should be at least equal to it's diameter
Stevie_P - 10/10/15 at 04:53 PM
I think the consensus (and the sensible thing to do) seems to be to get some longer studs.
What's the best way to get the originals out? Knock them out with a large hammer or try and press them out?
Had a quick go with a hammer and think it's going to take some effort...
iank - 10/10/15 at 05:26 PM
Press is best if you have access to one, but be careful if using a vice as a press
http://locostbuilders.co.uk/viewthread.php?tid=180812
ian locostzx9rc2 - 10/10/15 at 05:41 PM
Warm the hub up a bit and they normally come out with a hammer.
