has anyone fitted 205 by 17 on an indy if so what offset also what percentage 205 by 40 or 50 by 17
many thanks
tony
et 38 just fitted under rear arches had to remove return on the wings i am thinking that a et of 30 would make that better not sure on that. we fitted 205 40 17's
Got a feeling that ET 30 as opposed to ET 38 will bring the wheels out further....
My 2 pennorth
Pete(Oldgit)
Yep pete, you're right.
205/40 17 has roughly the same rolling diameter as 205/50 15, which is often used on Indys. I would have said that, if anything, go up to ET42, but
watch the wheels on the inside.
Adam
205/40/17s have caused me some problems. they're et38, and are not too bad for clearance so you may be better with something like an et40 odd.
had to have et38 as that's the biggest offset you can get pro race 1s in
however, the cycle wings are far too small for 17's and leave about a 1/2" gap at the front (to cover the rim vertically)
on one side and about 2" on t'other, (based on bonding the very rear edge to the rear bar of the wing stay, not so very strong). obviously
with 15s, the diameter is 1"less so you get away with it..............well you would if both wing stays were identical, but they're not. one
top bracket is misaligned so needed rewelding.
anyway, the long and short of it is the mk cycle wings won't fit, unless you can suggest to the sva man that you don't need the vertical
section of the rim to be covered.
i have ordered dax cycle wings, but they wont arrive til a fortnight after christmas, 3 weeks late
southern suppliers are really starting to pi*s me off
incidentally, does anone know if the new mk cycle wings are any bigger, ie more wheel coverage? snoopy, any light to be shed? any chance of some
bespoke bigger ones? i'd rather give money to mk than dax!
tom
I fitted ET 40 offset 205 40 17s to my Indy blade no problems at all.
