IVA passed and Registered with DVLA. Now for the mods. I have a windscreen and side pillars provided by MK which I am now trying to fit. Does anyone have any photographs of windscreens fitted to their cars, as the profile of the windscreen does not follow that of the scuttle and I've got a gap between the windscreen and the scuttle at the edge radii. Also can anyone advise on what they have done with the tail of the rubber gaiter/seal that acts to seal the bottom of the windscreen with the scuttle?
http://www.locostbuilders.co.uk/photos.php?action=gal&user=mookaloid&folder=Indy%20Screen
will this help not my car so can't help with the fitting
jacko
Thanks that helps a lot. Was not sure whether it goes above the right angled return or butted up against it. Looks like it butts up against it so tomorrow will get it fitted.
Mine butted up against the right angle.
you will have a gap as iirc the scuttle is not equal at both sides
I left a length of the rubber gaiter so that it could be pulled down the side and be clamped down by the screen supports to the scuttle.
Thanks Colin
Dave
