Hi. Short and sharp question, can someone tell me what these components are?
They came with the MK kit with all the other things in a box. Thanks
Thats a rivinut setting tool.......very sought after in this forum
That's the type I have from MK, I usually get a pair of moleys on the big 'nut' and a ratchet on the brass nut, add a little oil and
tighten away.
Does a good job too as long as you can keep it straight
Ditto - be v.careful with the M4 if you got one!
Cool. Thanks
I reckon it's the thing I have found most handy, very well made and much better than the cheap one I had wich broke almost immediately!
