Need to drain the brakes - anyone know how much brake fluid I need? (sierra running gear).
eg will 0.5L do it?
Also was going to replace with this:
Motul RBF 600 Factory Line RBF600 Performance Racing Brake Fluid 500ml 0.5L
H
[Edited on 17/10/16 by hazardpro]
Think I needed 1.5 later last time I fully changed the fluid
I use ATE super blue (not blue anymore)
https://www.amazon.co.uk/ATE-03990162022-Type-Brake-Fluid/dp/B003VXRPL0
Have been told that the dot4 is better for track use
Your need a min of a litre
Suspect you will get away with 500 ml but prob safer to buy 1L just in case. RBF600 is a very common choice for track day use, certainly it works for me.
Perfect thanks guys!
