I've stripped my wishbones from the car to have them powder coated.
Are the bottom ones sided O/S N/S or are they identical.
When i place them on top of each other they look identical with regards to geometry
The top ones are quite obviously different and sided.
Also, do I use Austin maxi bottom ball joints? I may as well replace them too
[Edited on 13/2/17 by flanders]
If it the Indy yes they are both the same
I do not know about the Indy R but someone will be along to soon to at yes or no on that
Kev....
Yeah sorry is an original Indy, that's good then, it's just some of the parts sites list them as being sided...but I couldn't see a difference
Having built an original MK Indy some years ago I can verify that the front lower wishbones are NOT handed.
thanks guys, much appreciated
