Has anybody any dimensions of mk wishbones?
Im interested in how they compare to
standard book ones.
Trueblue
My early type MK 'bones have the mounting bush sleeves set at 352mm, whereas the book dimension is 343mm.
See next post for pic comparison.
[Edited on 21/1/05 by Dick Axtell]
Following pic shows Luego type on the left, MK early (non-Indy) type on right.
Luego is fairly close to book drg.
what diameter are the wishbone tubes the leugo ones look to be a larger diameter
the reason i ask is there was a thread about wishbones bending at the point where the shock plate and whishbone meet
the conclusion seemed to be the shape of the plate (sharp corner ) concentrated the load on the wishbone tube and either a larger diameter whishbone
tube or a better shock plate design (with a gradual taper to spead the load) was better
cheers dave
Hey, that's my floor !!
Have you changed the Indy ones also?
snoopy how long have you been doing them like that they look much better (stronger) and is that oval tube?
how much are they per pair
cheers dave
Originally posted by snoopy
the locost ones have been like this quite awhile yes there oval and same price as before
as to indy tops then yes due to market forces we are jiging up with some designs in oval
