hi all
done a silly thing and need help.
I stripped my rear brakes down to have the back plates shot blasted.now putting them together I find I've dropped a few B#######KS and mr haynes ain't
no use
there are two holes in the back plate 1 for the handbrake cable 1 for the plastic plunger 1 is just a hole the other has a sleeving in it so which one
is which.
the plastic plunger which way in does it go narrow part on the shoe and wide part outside or vice versa.
on the slave cylinders is the bleed nipple towards the rear of the car
finally the handbrake cable does it feed in from the rear or front of the plate
many thanks
tony
cable comes in from the front,i think the backplates are not sided ie the cable goes in 1 hole and the plastic thingy goes in the other,big bit inside
with a spring pushing it outwards,as for where the brake pipe goes ,it dont matter.
