hub nut and shaft stick out just enough not to let me put my wheel centre caps on
Help needed!
You put it together right?
probably not, will take a piccy and post in asap your inspection guvnor!
here's a pic of the rear hub nut
[img][/img]
here is a pic of the wheel on the front
[img][/img]
Yeah that happened on my rears too...
space it out if you really want the covers on, or space the cover out
[Edited on 24/2/05 by macspeedy]
Yeah, I didn't fit my covers, I painted the end of the stub axle and nut silver instead.
Just grind 1/8" of end of stub and it'll fit!
Thats what i did with mine.
You'll find plenty of metal before start of thread.
Think that will work, hacksaw would take ages
, i can also take the badge back off the cap and make a suitable hole in the cap ( 2mm thick ) then
stick the badge back on.
Its a long shot but it might just work!
"COME BACK CHUCK"
Sorry my age is showing............ i loved them CHEWITS adverts
Yes - I had same issue on my offside rear and just took enough with an angle grinder for the centre to fit nicely!
Regards, Mark.
