Yesterday i brought a set of pedals of MK, from Stafford, but they didnt have any bushes or brackets, but i can make them up at collage, but i never
got the size of bolt they use to hold them in place, so does anyone know what size they need to be
Thanks Very Much
Phil
Hi Philip,
Think they use M8's and nylon as the insert for the pedals.
Mark
can confirm they are M8.
Thank V much
The brackets you need to manufacture yourself and weld to the chassis - if you need any help see our website. This should give you some idea
Sry 2 ask more questions, but can you plz tell me the thickness of the metal used to make the brackets
Thanks again
Phil
3mm if memory serves.
Be a lot easier to ask Phil to post you some nice laser cut jobbies.
the brake and clutch pedals are made out of 3mm but im not sure on the brackets themselves.
clutch and accelerator are 6mm and 3mm laser cut plate, brake pedal is 6mm bar.
all the brackets are 3mm plate.
and once again, here is my picture of the MK PEDALS, before you ask
tom
[Edited on 16/3/05 by indykid]
