thought i'd seen this article..found it at last in nov 04 kitcar mag... it states bottom of dashboard has sharp edge which has failed on
previous sva tests.a rubber strip is acceptable to raws cardiff based sva test centre.. any one had experience of passing at other test centres with
just a rubber strip
Hold the camera a little steader (rest it on something ideally) and set it to macro (if theres an option. with digital cameras theres no reason not to
take loads of photos till you have a good one.
I might be able to read the artical then.
