Can anyone suggest/recommend a throttle cable to connect the MK throttle peddle to a Weber 32/36 DGV carb?
Nick
I'm using a throttle cable from a mk3 cvh escort. The MK pedal has the ball from the mk3 pedal welded to it fot the cable to attach to. The mk3 cable is virtually identical to mk2 cable but a lot longer.
Not quite as I explained in my u2u ,but you get the idea..........
