Ordered chassis and lots of other bits from Martin on xmas eve! What a great bloke! He reckons he has sold 250 kits this year!!! That must be one of
the most in the entire industry!! Dax sold 150, which was its best ever year! Also ordered jetting/airfilter kit from TTS Performance. Once the
chassis arrives in mid march the engine should be running a dream and ready to bolt staight in!!
The big plan is to be able to drive it next xmas eve!
If you are going to SVA your Car you would be better leaving the TTS kit off. UI took my to TTS before SVA and the CO and hydro carbon etc readings
were miles too high. After putting on a new unaltered carbs it was almost OK. The balde ran with the TTS filter on wihtout the new jets. In the end
had to use a cat system (which MK is now renting out as he bought it off me). It was a 98 blade trying to pass the strictest emission tests
Jim
[Edited on 27/12/02 by Jim]
You should be driving it before next xmas eve. We built two indy blades this year in about 9 months
Jim
