Could anyone tell me what they have done for a gearbox mount? any pics??
I'm using the original that came with the type 9 i'm putting in this week,i will post a pic as soon as poss.
If you look in the links i'm sure there is an indy build that shows the mount in situ
[Edited on 29/12/02 by bob]
I used the std Type 9 g/box mount and it was too soft under hard cornering/power and the prop shaft hit the tunnel. This was fixed by fitting a Westfield replacement parts which is about £12 and is a more solid rubber block - uses the same mounting points!!!
