Hi All
I can't remember which hole is the fuel out and which is the breather on my MK tank. I have marked them A & B on the photo.
And yes i know what the big one is for.....putting me beer in!
Image deleted by owner
[Edited on 27/9/05 by donut]
a is feed, b is breather or return
hth
tom
Wow that was quick!!
Thank you
Andy,
Blow into a and b - if air passes it's fuel out. If not it's breather... MK don't normally pre-drill the breather just in case the tank
cap has a breather built in. (They may have changed that)
If I'm wrong - A should go to bottom of tank B won't.
Mr Hellfire Sir, you are a genius!!
Thank you!
Just chucked your old plastic tank away.... I tried and tried, but couldn't stop it leaking
So got a new plastic tank from Aeon, bit of a squeeze but it fits
yeah i never did get my money back from plastic tank man....the theiving bast***
