Hi all
I've been threatening to buy an Indy for a while and yesterday I did the deed. It's a blade engined beast and I had a blast driving it home
the 30 or so miles from the seller's house.
The car appears straight, corners like nothing else I've owned, brakes well when you stamp on the middle pedal and generally seems to be in good
order. Time will tell.
My list of jobs so far:
1. Gear shift operating the wrong way for me.
2. LSD needs collecting and fitting.
3. Sump needs drain plug moving and baffle.
4. Loud pedal and brake are not well positioned for heel and toe.
5. Could do with a service, been garaged for a few months.
6. Driver needs to learn how to move off from a standstill without stalling!
Cheers all for the help, advice and parts so far. It won't be the last of any that I'll need.
no need to say "enjoy", cos you will enjoy........
congratulations on buying the car!
now all you need to do is join the owners club
To take off without stalling.....loads revs and slip the clutch..... and if you would be so kind as to take the silencer off and do it outside my next door neighbour's house at 1am i would be most chuffed
You'll get used to it in no time!
let the fun begin!!!!
Welcome to the wonderful world of BEC's!!
