MK Interior trim
whitestu - 22/11/05 at 09:34 AM
Does anyone know if the plastic interior trim included with the deluxe kit includes interior side panels - I phoned MK and they said it didn't, but they didn't seem too sure. The pieces I got in my kit are the rear panel and four pieces for the transmission tunnel.
Stu
donut - 22/11/05 at 09:38 AM
If you mean the side pannels that attach inside the car on the drivers right and passengers left then yes you should have some in the delux kit, well i did!
welderman - 22/11/05 at 09:41 AM
Mine came with all the inside panels in the Delux kit
ReMan - 22/11/05 at 09:46 AM
And mine!
Worrying
zxrlocost - 22/11/05 at 10:07 AM
unorganisation again
I am with whitestu
large rear panel and 4 transmission tunnel parts
ditchlewis - 22/11/05 at 10:57 AM
Mine also, but i used them all as templates to cut aluminium panels. and then covered the plastic with vinyl trim which is easy to remove.
Ditch
scotlad - 22/11/05 at 11:20 AM
Mine certainly did
greggors84 - 22/11/05 at 11:39 AM
In mine i got 5 ali panels, one for the rear bulkhead behind the driver, then ones for the left and right of the driver and passenger. Didnt get a tunel top though.
I didnt get any plastic interior trim, but i did get my kit 2 years ago.
Jonte - 22/11/05 at 12:03 PM
My Deluxe kit that arrived in febraury 2004 included interior trim panels in plastic.
Only used the parts for the tran tunnel yet
whitestu - 22/11/05 at 12:23 PM
I have clarified this with Phil at MK. He says that the side panels are no longer included. They recommend trimming the sides with carpet as a neater solution.
Stu
asn163 - 22/11/05 at 12:24 PM
I got the rear and tunnel plastic panels but no sides.
zetec - 22/11/05 at 09:57 PM
Knock up your own, you can get what you want and it doesn't cost much. Making my trim infill panels (for trimming side panel insides) was far easier than getting the single piece ones to fit I had first time round!
