Visited my local radiator stockist and manufacturer, very helpfull had every type looked at the escort rad that a lot of people have been using but
just to pass on info the capri radiator is slightly taller has better mounting flanges and when fitted at a slight angle fits perfectly taking up
nearly all the room in the nose cone and its designed to cool a pinto, result.
How much was the Rad?
But is it not better to have a smaller radiator mounted upright?
It cost £70 inc vat, the angle is about 10 don't see any down side in that!
Which model capri did the rad come from ?
I prity sure its the 1600 and 2000 rad but i'll double check.
But which model,MK 1/2/3 ?
Ah! I'll have to check tommorrow.
1974 - 1988 presume thats the mk3?
That covers Mk2 & 3,thanks for that
You'll need to get the filler neck cut off and plated up and use a expansion tank as you'd need to keep taking the nose off also probably be below the head not tried it yet but from what i have seen most cars have expansion bottles any way..
