MK Full Roll Cage
mackei23b - 23/2/06 at 05:11 PM
Hi there
I am looking at a full cage for my Indy at later date, but would like to put the mounting plates in just now to allow an easier update later on.
I'd be gratefull if anyone with a full MK cage could posts a couple of pictures of where the cage mounts to the chassis.
many thanks
Ian
Avoneer - 23/2/06 at 06:00 PM
Speak to Martin at MK Engineering as he recently did mine and has all the measurements.
Mine was weld on, but easy to make it bolt-on.
The front legs mount on two triangles welded to the chassis below your knee and the rest is normal.
Pat...
shortie - 23/2/06 at 07:02 PM
This pic may help
Picking up chassis at MK 2
mackei23b - 23/2/06 at 07:20 PM
Thats great
Many thanks
Ian
procomp - 24/2/06 at 09:18 AM
The only thing with that cage is that if you are ever going to use it under msa regulations scruteneers have been known to moan about having the front to rear tube less than 50mm right above your head . and quite rightly so.
cheers matt
