Indy clutch cable / pedal
whitestu - 24/5/06 at 10:08 AM
Hi
Any suggestions on how to connect the cable to the pedal?
Does an adjuster need to be incorporated?
Stu
ditchlewis - 24/5/06 at 10:10 AM
MK do a connector kit that incluses the adjuster.
Ditch
cryoman1965 - 24/5/06 at 10:20 AM
I have a pinto with a type 9 box and have used a mk 2 escort cable. This has an adjuster at the clutch end. Pedal end has an eyelet. Used nylock nut, bolt and and 2 washers. Not on the road yet but seems ok.
Hope this helps
Regards Nige
