how many bolts do you have on your roll bar ? and how many does sva require?
mine had 4 each side
when you say had, does that mean you've now sold it ?
Mine has none its welded
MSA minimum is 3 if that helps.
Get Justin to weld it on for you
Edit ..Did you get that tps mounted ?
[Edited on 27/5/06 by big_wasa]
SVA doesn't require a roll bar. How many road cars have them?
i had 3 either side, 2 on the inside corners, and one on the middle of the outer edge. m10, a4 stainless button head. if i had my time again, i'd
have used m10/12 bzp, 12.9 as a matter of course.
my new one's got a welded, backbraced roll bar, with diagonal, and crush tubes for the bolting on of the front half of the cage.
the thought of crashing like i did again into something bigger than a corsa scared me enough to get some proper protection this time.
tom
