Simple Question, but I'm nowhere near my exhaust ATM.
Can anyone tell me what size of clamp I need for a standard MK exhaust (Pinto) to clamp the tail pipe to the silencer
Scott
i got an exhaust from mk last week, very nice work i must say,anyway, the outlet pipe is a 2" diameter stainless steel pipe, if you are going to
run a silencer with a 2" inlet then i guess you will need a clamp that is suitable for 2" pipe, if you are going to run a big fancy silencer
with a bigger diameter barrel and therefore a bigger inlet pipe, you will need to get an adapter pipe that has an inlet to fit a 2" pipe (from
the exhaust)and an outlet to fit a 2.5" pipe (for the silencer) and hense you will need 2 clamps
hope this helps
Alex
