Does anyone know how much does the full rollcage weigh and is it a straight foward bolt on or not?
matt
not sure about wieght but mk welded mine in, in about six places
Mine was by MK Engineering.
Weighs 30kg and is welded at the 6 points of leg contacts.
Cost is anything between £300 and £400.
Pat...
Mine was by MK in 2002 (before they split into MK sportscars and MK Engineering) , I asked them to make mine 'bolted'. Not easy to fit in
with rear panel on, needs loads of tensioning, and with my boot lid configuration, now impossible to remove.
Fozzie
ahem, £300 and £450 +vat pat.
i can tell you how much the front half of a cage weighs when it comes back from the powder coaters.
tom
