Hi
I've been reading the threads after looking at wheels today and I'm slightly confused
The manual states an ET38 offset for a 15x6 wheel. I've seen plenty of nice wheel designs but the widths seem to start at 6.5
From the thread I understand that the offset and wheel width are interlinked so can anyone summarise for idiots like me max wheel widths for Indy and
minimum offsets you can use without causing problems with arches front and rear
thanks
You are correct in saying that the wheel width and offset are linked. The offset is purely the amount of distance between the hub face and the centre
line of the wheel. To use a 6.5" rim you will need a ET32 to get the same amount of clearance on the inside of the rim with 12mm required on the
outside. Alternatively you could go for an ET44 and get the same clearance on the outside and 12mm on the inside. This
link might help to shed a bit more light.
[Edited on 7-10-06 by RazMan]
thanks for that it cleared up some of the confusion with offset and wheel widths
so if a 15x6 wheel with Et38 was fitted how much less offset could I afford before the wheel wouldn't fit the arch on an Indy?
Can anyone help with that question
Originally posted by RazMan
. This link might help to shed a bit more light.![]()
Using the calculator, a 15x7 ET42 will give you 2mm less clearance on the outside and 10mm less on the inside.
will give you the same inside but 12mm more to the outside. You don't really qualify what you are trying to achieve by asking what it should be. Are you trying to fill the arch more or maintain clearance for the inside?
I want to use other wheels and the new ones only come in 7" widht. The wheels I have now is very close to the outer arch, so I only want to increase the width on the inner
ive got a lovely set of racing dynamics 16 rims on mine which are going to be sale very soon black rims not a mark on them make me a offer. u2u if you want pics.
